LaCie 8TB Porsche Design 3.5 USB3.0 - Grey
£195.51
Delivery:
Key features
  • Accelerate your backup with USB 3.0
  • Porsche design form, LaCie function
  • Safe, strong, and aluminum
  • Form Factor: 3.5"
  • Capacity: 8TB
  • Interface: USB 3.0
Product codes
With the P'9233's USB 3.0 interface, you'll be able to get the job done faster than ever before. Speeds up to 5Gb/s allow you to transfer a 700 MB video file in just under 7 seconds. Back up your photos, exchange audio and video files with your friends, or make sure that your important files are kept safe. With the P'9233, the possibilities are endless.
Product Description LaCie Porsche Design P'9233 - hard drive - 8 TB - USB 3.0
Type Hard drive - external (desktop) - automatic backup, Apple Time Machine compatible, LED status indicator, on/off switch
Capacity 8 TB
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Features Automatic backup, Apple Time Machine compatible, LED status indicator, on/off switch
Power Source Included AC adapter
Dimensions (WxDxH) 120 mm x 190 mm x 38 mm
Weight 1 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LaCie 8TB Porsche Desi...
£195.51
