LaCie Lacie 12TB 2big Quadra USB 3
Key features
  • Speed and security for creative professionals
  • Hot-swappable disks for non-stop data access
  • Quadruple interface connectivity on PC/Mac
  • Aluminum heat sink design for greater reliability
Product codes
This quadruple interface professional 2-disk RAID delivers fast speed, large capacity and data security. With eSATA 3Gbits, FireWire 800, FireWire 400 and Hi-Speed USB 2.0, it provides complete universal compatibility with any PC or Mac. The easy-to-use 2big Quadra comes with two extractable, lockable and hot-swappable disks for a user-controlled solution. With four RAID levels, it meets your storage needs, whether it's security, capacity, speed or a combination. With burst transfer rates as high as 165MB/s (eSATA), it's ideal for audio/video projects. The sturdy heat sink metal design provides 60% more surface area for natural heat dissipation.
LaCie 2big Quadra - hard drive array
Hard drive array
Total Array Capacity
12 TB
FireWire 800, USB 3.0
2 (installed) / 2 (max)
Worldwide
Storage Controller
RAID 0, 1, 0+1
Hard Drive
2 x 6 TB HDD - hot-swap
Windows 8 or later, Apple MacOS 10.12 Sierra or later
AC 120/230 V - 50/60 Hz
9 cm x 20 cm x 18.2 cm
3.7 kg
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
LaCie Lacie 12TB 2big...
