Lenovo 16GB TruDDR4 Memory (2Rx4, 1.2V) PC4-17000 CL15 2133MH...
Lenovo 16GB TruDDR4 Memory (2Rx4, 1.2V) PC4-17000 CL15 2133MHz LP R
£583.84
Delivery:
Product codes
Boost the capabilities of your server and keep it performing reliably with IBM memory. Upgrading your memory is a cost-effective way to improve system performance when insufficient memory and hard drive paging is slowing your applications down.
  • Faster start-up times with fewer delays during routine operations.
  • More programs running simultaneously.
  • Easy toggling between several open applications.
  • Rigorous supplier qualification processes for ensured quality.
Lenovo TruDDR4 - DDR4 - 16 GB - DIMM 288-pin - registered
RAM memory
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Dual rank, registered
Voltage
1.2 V
IBM 46W0796
1 year warranty
System x3550 M5 5463; x3650 M5 5462; x3850 X6 6241; x3950 X6 6241
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Lenovo 16GB TruDDR4 Me...
£583.84
