We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Product Description | Lenovo D24f-10 - LED monitor - Full HD (1080p) - 23.6" | Device Type | LED-backlit LCD monitor - 23.6" | Adaptive-Sync Technology | AMD FreeSync | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 144 Hz | Pixel Pitch | 0.2715 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 3000000:1 (dynamic) | Response Time | 1 ms (extreme), 3 ms (typical), 5 ms (Off) | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC (CIE 1931) | Input Connectors | HDMI, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Raven black | Dimensions (WxDxH) - with stand | 56.6 cm x 44.43 cm x 21 cm | Weight | 3.96 kg | Localisation | English / United Kingdom | Compliant Standards | CCC, CEE Tier 3, TUV Rheinland Low Blue Light Certification, DisplayPort 1.2, EU RoHS | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.6" |
Panel Type | TN |
Pixel Per Inch | 94 |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
Dimensions (WxDxH) | 56.6 cm x 44.43 cm x 21 cm - with stand |
Weight | 3.96 kg |
Mechanical | |
Tilt Angle | -5/+22 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x HDMI adapter |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 32 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 56.6 cm - depth: 44.43 cm - height: 21 cm - weight: 3.96 kg , Without stand - width: 56.6 cm - depth: 5.09 cm - height: 34.44 cm - weight: 3.35 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 62.8 cm |
Shipping Depth | 13.9 cm |
Shipping Height | 52 cm |
Shipping Weight | 5.71 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
