We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
When it comes to performance, Lenovo G27-20's got game. Let's start with a look at its 27" 1920x1080 Full HD resolution In-Plane Switching panel display that delivers startlingly lifelike lighting effects to gameplay thanks to HDR decoding on the fly. It never misses a beat, even in the most intense moments, because its speedy 144Hz refresh rate and 1ms MPRT response time, coupled with AMD FreeSync Premium, remove image stutter, break, tear, and streak from the experience, leaving a smooth, fluid unspoiled session. Besides, the 99% sRGB color gamut display featuring true 8-bit color will make your gameplay impressive for sure.
And, as bright as this display is, users can watch comfortably because TÜV Rheinland Low Blue Light and TÜV Rheinland Flicker Free technologies can protect eyes from blue light harm on a sliding scale, as well as cutout screen flicker. All of these enhance your viewing pleasure and reduce chance of eye fatigue. Aside from eye comfort, G27-20's future-cool form factor helps in comfortable sitting, too. Its upgraded Vector V base with modern blue accent also lifts the screen head and tilts to always be in the ergonomic position for endless hours of comfortable binge-watching a show that just dropped.
Product Description | Lenovo G27-20 - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class E | Power Consumption (On mode) | 19 W | Adaptive-Sync Technology | AMD FreeSync Premium | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 144 Hz | Pixel Pitch | 0.3114 mm | Brightness | 400 cd/m² | Contrast Ratio | 1000:1 / 3000000:1 (dynamic) | Response Time | 1 ms (MPRT), 3 ms (extreme), 5 ms (normal) | Colour Support | 16.7 million colours | Colour Gamut | 99% sRGB | Input Connectors | HDMI, DisplayPort | Display Position Adjustments | Height, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Raven black | Dimensions (WxDxH) - with stand (lowest position) | 61.242 cm x 39.279 cm x 25.997 cm | Weight | 5.94 kg | Localisation | English / United Kingdom | Compliant Standards | CCC, CEE Tier 2, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, RoHS 2002/95/WE | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 27" |
Panel Type | IPS |
Pixel Per Inch | 82 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | 8-bit Colour Depth, 3-side NearEdgeless, HDR decoding, 99% sRGB colour gamut |
Dimensions (WxDxH) | 61.242 cm x 39.279 cm x 25.997 cm - with stand (lowest position) |
Weight | 5.94 kg |
Connectivity | |
Interfaces | DisplayPort 1.2 , HDMI , Audio line-out (mini-jack) |
Mechanical | |
Tilt Angle | -5/+22 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), integrated cable management |
Cables Included | 1 x DisplayPort cable - 1.8 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 19 kWh/1000h |
Power Consumption HDR (On mode) | 32 kWh/1000h |
Power Consumption (Typical) | 22 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
Included Software | Lenovo Artery |
Dimensions & Weight | |
Dimensions & Weight Details | With stand (lowest position) - width: 61.242 cm - depth: 39.279 cm - height: 25.997 cm - weight: 5.94 kg , With stand (highest position) - width: 61.242 cm - depth: 52.279 cm - height: 25.997 cm - weight: 5.94 kg , Without stand - width: 61.242 cm - depth: 36.703 cm - height: 4.795 cm - weight: 3.68 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 86.87 cm |
Shipping Depth | 15.99 cm |
Shipping Height | 47.75 cm |
Shipping Weight | 8.25 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
