Lenovo G27-30 27" FHD 165Hz 1ms Gaming Monitor
£209.98
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 27-inch display
  • 1,920 x 1,080 FHD resolution
  • 165Hz refresh rate
  • AMD FreeSync Premium Technology
  • Diagonal Size: 27in
  • Response Time: 1ms
Product codes
When it comes to performance, Lenovo G27-30's got game. Let's start with a look at its 27-inch 1,920 x 1,080 Full HD resolution display that delivers startlingly life-like lighting effects to gameplay in a luminous 3500 cd/m², thanks to HDR decoding on-the-fly. It never misses a beat, even in the most intense moments, because its speedy 165Hz refresh rate and 1ms MPRT response time, coupled with AMD FreeSync Premium, remove image stutter, break, tear and streak from the experience, leaving a smooth session.
Besides, the 99% sRGB color gamut display featuring true 8-bit color will make your gameplay impressive for sure. And, as bright as this display is, users can watch comfortably because TÜV Rheinland Low Blue Light technology can protect eyes from blue light harm on a sliding scale, as well as cut out screen flicker. All these enhance your viewing pleasure plus a vastly reduced chance of eye fatigue.
Product Description Lenovo G27-30 - LED monitor - Full HD (1080p) - 27" - HDR
Device Type LED-backlit LCD monitor - 27"
Energy Class Class E
Adaptive-Sync Technology AMD FreeSync Premium
Panel Type VA
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 165 Hz
Pixel Pitch 0.311 mm
Brightness 350 cd/m²
Contrast Ratio 3000:1 / 3000000:1 (dynamic)
Response Time 1ms (MPRT), 4 ms (Level 4), 5 ms (Level 3), 6 ms (Level 2), 7 ms (Level 1)
Colour Support 16.7 million colours
Colour Gamut 99% sRGB, 90% DCI-P3
Input Connectors 2xHDMI, DisplayPort
Display Position Adjustments Height, tilt
Screen Coating Anti-glare
Voltage AC 100-240 V (50/60 Hz)
Colour Raven black
Dimensions (WxDxH) - with stand (lowest position) 61.41 cm x 23.92 cm x 39.44 cm
Weight 5.8 kg
Localisation English / United Kingdom
Compliant Standards CCC, CEE Tier 1, EU RoHS 2002/95/EC, TUV Eye Comfort certified, TUV Eyesafe Display Certification, TUV Rheinland Low Blue Light (Hardware Solution)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£209.98
