With the Lenovo G34w, gaming is more immersive and equally thrilling. The WQHD, curved panel draws you in and places you amid the games you play. Blending perfectly with your gaming rig, a refresh rate of 144Hz coupled with AMD Radeon FreeSync technology makes for smoother gameplay that's free of screen-tearing and input lags. Low blue light certification allows for extended hours of entertainment without hurting or straining your eyes.
Product Description | Lenovo G34w-10 - LED monitor - curved - 34" | Device Type | LED-backlit LCD monitor - 34" | Energy Class | Class F | Power Consumption (On mode) | 26.6 W | Curved Screen | Yes | Adaptive-Sync Technology | AMD FreeSync | Panel Type | VA | Aspect Ratio | 21:9 | Native Resolution | 3440 x 1440 at 144 Hz | Pixel Pitch | 0.232 mm | Brightness | 350 cd/m² | Contrast Ratio | 3000:1 / 3000000:1 (dynamic) | Response Time | 4 ms | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC | Input Connectors | HDMI, DisplayPort | Display Position Adjustments | Height, tilt | Screen Coating | Anti-glare | Voltage | AC 100/240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 80.86 cm x 25.996 cm x 41.184 cm | Weight | 8.1 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | RoHS, TUV Rheinland Flicker Free Certification, TUV Rheinland Eye Comfort Certification | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 34" |
Curved Screen | Yes (1500R) |
Panel Type | VA |
Pixel Per Inch | 109 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | Integrated cable management, Low Blue Light Mode, Flicker Free technology, NearEdgeless, 72% NTSC colour gamut |
Colour | Black |
Dimensions (WxDxH) | 80.86 cm x 25.996 cm x 41.184 cm - with stand |
Weight | 8.1 kg |
Connectivity | |
Interfaces | DisplayPort , HDMI , Audio line-out (mini-jack) |
Mechanical | |
Tilt Angle | -5/+22 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DisplayPort cable - 1.8 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100/240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 26.6 kWh/1000h |
Power Consumption (Typical) | 43 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand (lowest position) - width: 80.86 cm - depth: 25.996 cm - height: 41.184 cm - weight: 8.1 kg , With stand (highest position) - width: 80.86 cm - depth: 25.996 cm - height: 54.184 cm - weight: 8.1 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 94.3 cm |
Shipping Depth | 28.1 cm |
Shipping Height | 48.9 cm |
Shipping Weight | 11.3 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
