Lenovo Laser Wireless Mouse
£27.21
45 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Size designed that balances ergonomics with comfort and portability
  • Exclusively contoured for both right and left-handed usage with soft touch finish for all-day use
  • 1600 dpi resolution, Laser sensor
  • Works on most surfaces; no mouse pad required
  • 4-way scroll wheel which also works as button and function can be changed via driver
  • Micro-size USB receiver stores neatly inside the mouse for travel
  • Unique battery compartment with hinge design securely holds and eases battery removal and installation
  • Battery life indicator
  • 2.4 GHz wireless technology
Product codes
The portable, ambidextrous Lenovo Wireless Laser Mouse is perfect for anyone looking for a compact mouse to use every day and while on-the-go. Scroll through documents, spreadsheets, and more with increased accuracy and control with its high-definition laser sensor. An advanced power management system, a high-efficiency laser sensor, and an off switch help to maximize your battery life.
Lenovo - mouse - 2.4 GHz
Mouse
Wireless - 2.4 GHz
5.6 cm x 9.6 cm x 3.2 cm
108 g
Worldwide (excluding Argentina, Brazil, Korea, Paraguay)
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Movement Resolution
1600 dpi
Scrolling wheel (4-way), battery indicator
2 x AA type
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
1 year warranty
100e (2nd Gen); 100e Chromebook (2nd Gen); 130-14; 300e (2nd Gen); 300e Chromebook (2nd Gen); 330-14; Chromebook C330; S330; IdeaCentre A340-22; L340-15; Legion Y7000; Y740-15; Y740-17; S530-13; ThinkCentre M715q (2nd Gen); ThinkPad E490; E590; L390; L390 Yoga; V145-15; V530-15; Yoga A940-27
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Lenovo Laser Wireless...
£27.21
