We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The Lenovo Legion Y27q-20 gaming monitor delivers an immersive gaming experience that's sure to get your pulse racing. The IPS wide viewing angle panel ensures stunning clarity with true colors. A 1ms response time and 165 Hz refresh rate give you the edge when it matters most. The innovative AMD Radeon FreeSync technology takes gameplay to a whole new level, churning out ultra-smooth visuals, reducing screen tearing and motion blur.
Product Description | Lenovo Legion Y27q-20 - LED monitor - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class G | Power Consumption (On mode) | 32 W | Adaptive-Sync Technology | AMD FreeSync | Features | USB 3.1 Gen 1 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | QHD 2560 x 1440 | Pixel Pitch | 0.2331 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 / 3000000:1 (dynamic) | Response Time | 1 ms (extreme), 2 ms (typical), 5 ms (Off) | Colour Support | 1.07 billion colours | Colour Gamut | 98% DCI-P3 (CIE 1931) | Input Connectors | HDMI, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Raven black | Dimensions (WxDxH) - with stand | 61.4 cm x 28.44 cm x 46.89 cm | Weight | 6.77 kg | Localisation | English / United Kingdom | Compliant Standards | CCC, RoHS, Directive 2002/95/EC, China Energy standard Tier 2, TUV Rheinland Eye Comfort Certification | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 27" |
Built-in Devices | USB 3.1 Gen 1 hub |
Panel Type | IPS |
Pixel Per Inch | 109 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Dimensions (WxDxH) | 61.4 cm x 28.44 cm x 46.89 cm - with stand |
Weight | 6.77 kg |
Connectivity | |
Interfaces | HDMI , DisplayPort , USB 3.1 Gen 1 upstream (Type B) , 3 x USB 3.1 Gen 1 downstream , Headphone/microphone combo jack |
Mechanical | |
Tilt Angle | -5/+22 |
Swivel Angle | 30 |
Rotation Angle | 180 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), integrated cable management, headphone hook |
Cables Included | 1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB 3.1 Type A to Type B cable - 1.8 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 32 kWh/1000h |
Power Consumption HDR (On mode) | 58 kWh/1000h |
Power Consumption (Typical) | 50 Watt |
Power Consumption Sleep | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Software / System Requirements | |
Included Software | Lenovo Artery 2.0 |
OS Required | Microsoft Windows 7 / 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.4 cm - depth: 28.44 cm - height: 46.89 cm - weight: 6.77 kg , Without stand - width: 61.4 cm - depth: 6.34 cm - height: 36.87 cm - weight: 4.37 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 48 cm |
Shipping Depth | 71.5 cm |
Shipping Height | 22.5 cm |
Shipping Weight | 9.7 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
