Lenovo ThinkCentre M630e Tiny Intel Core i5-8265U 8GB 256GB S...
Lenovo ThinkCentre M630e Tiny Intel Core i5-8265U 8GB 256GB SSD Windows 10 Professional 64-bit
£477.22
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Big on performance
  • Tiny by design
  • Robust security
  • Versatile connectivity
  • Processor Type: Core i5
  • Operating System: Windows 10 Pro 64-bit Edition
  • Installed Memory: 8GB
  • Hard Drive Capacity: 256GB
  • Storage Type: SSD
Product codes
It's a small PC, but you can use it to get big things done. Solid specs including powerful processing, large memory and multiple storage options make the ThinkCentre M630e Tiny a compact powerhouse. The ThinkCentre ecosystem gives you extraordinary flexibility. Easy-to-install accessories let you attach your M630e Tiny to a projector, a wall, or the underside of a desk. You can also create your own modular AIO with a ThinkCentre Tiny-in-One monitor. Added benefit: you can save on costs by upgrading the display and the M630e Tiny on separate schedules.
The ThinkCentre M630e Tiny helps you keep your business data safe with security features like Smart USB Protection, which prevents malware from entering your system through the USB ports. A menu of I/O ports give you high-speed connectivity to peripherals for easy multitasking. And a USB-C data port makes it a snap to share information quickly. IT admins will love the Smart Power On feature, which enables remote device manageability with a simple keyboard shortcut.
Product Description Lenovo ThinkCentre M630e - tiny - Core i5 8265U 1.6 GHz - 8 GB - 256 GB - UK
Type Personal computer - tiny
Localisation Language: English / region: United Kingdom
Processor Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) (Quad-Core)
Cache Memory 6 MB
Cache Per Processor 6 MB
RAM 8 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller SATA (SATA 6Gb/s)
Hard Drive 1 x SSD 256 GB - PCI Express 3.0 x4 - M.2 2280 - TCG Opal Encryption, NVM Express (NVMe)
Optical Storage No optical drive
Graphics Controller Intel UHD Graphics 620
Networking GigE, 802.11ac, Bluetooth 4.2
Keyboard UK
Power AC 120/230 V (50/60 Hz)
OS Provided Windows 10 Pro 64-bit Edition
Colour Black
Dimensions (WxDxH) 17.9 cm x 18.29 cm x 3.45 cm
Weight 1.32 kg
Manufacturer Selling Program TopSeller
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - 1 year - on-site
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Lenovo ThinkCentre M63...
£477.22
