Marketing description is not available.
Product Description | Lenovo ThinkCentre M710q - tiny - Core i3 7100T 3.4 GHz - 4 GB - 128 GB - UK | Type | Personal computer - tiny | Localisation | Language: English / region: United Kingdom | Processor | 1 x Intel Core i3 (7th Gen) 7100T / 3.4 GHz (Dual-Core) | Cache Memory | 3 MB | Cache Per Processor | 3 MB | RAM | 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | 1 x SSD 128 GB - PCI Express 3.0 x4 - M.2 2280 - NVM Express (NVMe) | Optical Storage | No optical drive | Graphics Controller | Intel HD Graphics 630 | Networking | GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.1 | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Colour | Black | Dimensions (WxDxH) | 17.9 cm x 18.29 cm x 3.45 cm | Weight | 1.32 kg | Manufacturer Selling Program | TopSeller | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 3 years - on-site |
General | |
Type | Personal computer |
Product Form Factor | Tiny |
Built-in Devices | Speaker |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Colour | Black |
Processor / Chipset | |
CPU | Intel Core i3 (7th Gen) 7100T / 3.4 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Chipset Type | Intel B250 |
Cache Memory | |
Installed Size | 3 MB |
RAM | |
Installed Size | 4 GB / 32 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Dual channel memory architecture |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | SSD - M.2 2280 |
Capacity | 1 x 128 GB |
Interface Type | PCI Express 3.0 x4 |
Features | NVM Express (NVMe) |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Channel Qty | 1 |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 630 |
Video Interfaces | DisplayPort |
Max Monitors Supported | 2 |
Audio Output | |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Mouse Name | Lenovo Calliope Mouse |
Interface | USB |
Networking | |
Ethernet Controller | Intel I219-V |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Dual Band Wireless-AC 8265 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1 |
Features | Wake on LAN (WoL) |
Expansion / Connectivity | |
Bays | 1 (total) / 1 (free) x internal 2.5" |
Slots | 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 0 (free) x M.2 Card |
Interfaces | 6 x USB 3.1 Gen 1 (2 front, 4 rear) (one of them is Always On and fast-charging) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 2 x DisplayPort , 1 x serial |
Miscellaneous | |
Included Accessories | VESA mounting kit, adapter cage |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately), chassis intrusion switch |
Security Slot Type | Kensington security slot |
VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm |
Compliant Standards | RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3 |
Power | |
Device Type | Power adapter |
Nominal Voltage | AC 120/230 V (50/60 Hz) |
Power Provided | 65 Watt |
Efficiency | 88% |
Operating System / Software | |
Environmental Standards | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 6.1 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site |
Dimensions & Weight | |
Width | 17.9 cm |
Depth | 18.29 cm |
Height | 3.45 cm |
Weight | 1.32 kg |
