The compact ThinkCentre M series desktop boasts a footprint so small it can fit neatly on a bookshelf, behind a monitor, or even under a desk. Engineered to work in tough environments, this PC can handle anything from minor bumps to extreme temperatures and dusty conditions, so you can focus on growing your business and getting your work done.
Product Description | Lenovo ThinkCentre M720q - tiny - Core i3 8100T 3.1 GHz - 4 GB - 128 GB - UK | Type | Personal computer - tiny | Localisation | Language: English / region: United Kingdom | Processor | 1 x Intel Core i3 (8th Gen) 8100T / 3.1 GHz (Quad-Core) | Cache Memory | 6 MB | Cache Per Processor | 6 MB | RAM | 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | 1 x SSD 128 GB - PCI Express 3.0 x2 - M.2 2242 | Optical Storage | No optical drive | Graphics Controller | Intel UHD Graphics 630 | Networking | GigE, 802.11ac, Bluetooth 4.2 | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Home 64-bit Edition | Colour | Black | Dimensions (WxDxH) | 17.9 cm x 18.29 cm x 3.45 cm | Weight | 1.32 kg | Manufacturer Selling Program | TopSeller | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 1 year - on-site |
General | |
Type | Personal computer |
Product Form Factor | Tiny |
Built-in Devices | Speaker |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Colour | Black |
Processor / Chipset | |
CPU | Intel Core i3 (8th Gen) 8100T / 3.1 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Chipset Type | Intel B360 |
Cache Memory | |
Installed Size | 6 MB |
RAM | |
Installed Size | 4 GB / 32 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Dual channel memory architecture |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | SSD - M.2 2242 |
Capacity | 1 x 128 GB |
Interface Type | PCI Express 3.0 x2 |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Channel Qty | 1 |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel UHD Graphics 630 |
Video Interfaces | VGA, HDMI, DisplayPort |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Interface | USB |
Networking | |
Ethernet Controller | Intel I219-LM |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Dual Band Wireless-AC 3165 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ac, Bluetooth 4.2 |
Features | Wake on LAN (WoL) |
Expansion / Connectivity | |
Bays | 1 (total) / 1 (free) x internal 2.5" |
Slots | 1 (total) / 1 (free) x PCIe 3.0 x8 - low-profile , 2 (total) / 1 (free) x M.2 Card |
Interfaces | 3 x USB 3.1 Gen 1 (1 front, 2 rear) (one of them is Always On and fast-charging) , 1 x USB-C 3.1 Gen 1 (1 in front) , 1 x headphones/microphone (1 in front) , 1 x microphone (1 in front) , 2 x USB 3.1 Gen 2 , 1 x LAN (Gigabit Ethernet) , 1 x HDMI , 1 x DisplayPort , 1 x serial , 1 x VGA |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately), chassis intrusion switch |
Security Slot Type | Kensington security slot |
Compliant Standards | RoHS, Energy-Related Products (ErP) Lot 3, TUV Rheinland Ultra Low Noise Certification |
Power | |
Device Type | Power adapter |
Nominal Voltage | AC 120/230 V (50/60 Hz) |
Power Provided | 65 Watt |
Efficiency | 88% |
Operating System / Software | |
Software | Lenovo Vantage, Linkedin |
Environmental Standards | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 7.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - on-site |
Dimensions & Weight | |
Width | 17.9 cm |
Depth | 18.29 cm |
Height | 3.45 cm |
Weight | 1.32 kg |
