Lenovo ThinkPad Battery 68+ (6 cell)
£79.72
Delivery:
Standard: 1-3 working days
Key features
  • Lithium-ion (Li-ion) technology
  • 6-cell system battery
  • Over-discharge protection to prolong the life of the battery
  • Battery safeguard chip authenticates with Lenovo systems
  • Device Screen Size: [N/A]
  • Stock Status: In Stock
Product codes
The Lenovo ThinkPad Battery 68+ is compatible with the W550, T440, T440s, L450, T450s, T450, T550, X250 and X240 systems. This 6-cell battery utilises Lithium-Ion technology and allows you to stay unplugged for longer, providing the longest possible battery life. The battery can provide power for approximately 72 watt hours and is rechargeable. A safe flow of power is ensured by the over-discharge protection, which prevents damage due to incorrect voltage. Each one is safeguarded with a chip that authenticates with Lenovo systems.
*Battery life differs due to a multitude of factors, including features, battery conditioning, power management, applications, screen brightness and other customer preferences.
Product Description Lenovo ThinkPad Battery 68+ - laptop battery - Li-Ion - 6.6 Ah
Device Type Laptop battery
Weight 335 g
Battery Lithium Ion 6-cell - 6.6 Ah
Batteries Qty 1
Dimensions (WxDxH) 20.67 cm x 6.4 cm x 2.39 cm
Manufacturer Warranty 1-year warranty
Designed For ThinkPad A275; L450; L460; L470; P50s; T440; T440s; T450; T450s; T460; T460p; T470p; T550; T560; W550s; X240; X250; X260; X270
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Lenovo ThinkPad Batter...
£79.72
