We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Designed keeping style and functionality in mind, this sleek Lenovo L24e-20 monitor is all set to give you an incredible viewing experience. With the 23.8" NearEdgeless design and a 178°/178° wide viewing angle, the Lenovo L24e-20 monitor enables you to enjoy content consumption activities on a magnificent canvas. The TÜV Low Blue Light certification and flicker-free display reduces eye strain and makes long viewing hours comfortable. Also, you can adjust the monitor the way you want with the Quick Release Tilt Stand or mount it on a wall with VESA compatible slots to make extra desk-space. Plug in your gaming console, media player, or any other streaming device simultaneously with the multiple connectivity options.
Product Description | Lenovo l24e-20 - LED monitor - Full HD (1080p) - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class E | Power Consumption (On mode) | 15.2 W | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 53.95 cm x 19 cm x 40.27 cm | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | DDC/CI, RoHS, WEEE, TUV Rheinland Low Blue Light Certification, VESA TMDS |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Vertical Refresh Rate | 49 - 76 Hz |
Horizontal Refresh Rate | 54 - 90 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | Flicker Free technology |
Connectivity | |
Interfaces | HDMI , VGA (HD-15) , Headphones |
Mechanical | |
Tilt Angle | -5/+22 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable - 1.8 m |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 15.2 kWh/1000h |
Power Consumption (Typical) | 24 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
