We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Product Description | Lenovo ThinkVision M14 - LED monitor - Full HD (1080p) - 14" | Device Type | LED-backlit LCD monitor - 14" | Energy Consumption per Year | 15.53 kWh | Power Consumption (On mode) | 4.88 W | Features | USB PD 65 Watt | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.1611 mm | Brightness | 300 cd/m² | Contrast Ratio | 700:1 / 3000000:1 (dynamic) | Response Time | 6 ms | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC (CIE 1931) | Input Connectors | 2xUSB-C | Display Position Adjustments | Height, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Raven black | Dimensions (WxDxH) - with stand | 32.337 cm x 9.654 cm x 20.903 cm | Weight | 0.57 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | CCC, RoHS, ISO 9241-307, Directive 2002/95/EC, China Energy standard Tier 2 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 14" |
USB Power Delivery | 65 Watt |
Panel Type | IPS |
Pixel Per Inch | 157 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | Low Blue Light Mode, Mercury free, arsenic-free glass, Eye comfort mode, Eye-Care Technology, 8-bit + A-FRC Colour Depth |
Dimensions (WxDxH) | 32.337 cm x 9.654 cm x 20.903 cm - with stand |
Weight | 0.57 kg |
Connectivity | |
Interfaces | 2 x USB-C 3.1 Gen 1/DisplayPort Alt Mode with Power Delivery 2.0 (power up to 65W) |
Mechanical | |
Tilt Angle | -5/+90 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Clips |
Cables Included | 1 x USB-C cable - 1 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 6 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
On / Off Switch | Yes |
Software / System Requirements | |
OS Required | Microsoft Windows 7 / 8 / 8.1 / 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand (highest position) - width: 32.337 cm - depth: 9.654 cm - height: 22.003 cm - weight: 570 g , With stand (lowest position) - width: 32.337 cm - depth: 9.654 cm - height: 20.903 cm - weight: 570 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 40.2 cm |
Shipping Depth | 27.6 cm |
Shipping Height | 6.1 cm |
Shipping Weight | 1.67 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 7.1 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 30 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
