Lenovo ThinkVision P24h 23.8" 2560 x 1440 4ms HDMI LED M...
Lenovo ThinkVision P24h 23.8" 2560 x 1440 4ms HDMI LED Monitor
£239.73
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Native resolution of 2560 x 1440
  • Accurate color with factory calibration report
  • Lift, tilt, pivot, swivel stand for viewing comfort
  • Direct access button for automatic image setup and brightness allows quick and easy monitor setup
  • Kensington Lock slot for security
Product codes
The ThinkVision P24h-10 monitor has a glossy appearance with a full-function ergonomic stand. It offers a crystal clear borderless IPS display of 2560 x 1440 resolution and sRGB 99% color gamut, providing vivid, accurate images from a wide viewing angle. Moreover, each monitor has been pre-calibrated to obtain an accurate and consistent color with a factory calibration report. With built-in power and the rich connectivity of USB-C, HDMI, DP and DP out, P24h-10 satisfies diverse connection demand and can make multi-screen easier with daisy chain. USB-C can offer one-cable connection usage experience to customers. P24h-10 also has 4 USB 3.0 ports. Its full-function stand supports lift, tilt, pivot and swivel, which are all for your ease of use.
Product Description Lenovo ThinkVision P24h-10 - LED monitor - 23.8"
Device Type LED-backlit LCD monitor - 23.8"
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution WQHD 2560 x 1440 at 60 Hz
Pixel Pitch 0.2058 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 3000000:1 (dynamic)
Response Time 14 ms (grey-to-grey); 6 ms; 4 ms
Colour Support 16.7 million colours
Input Connectors 2xHDMI, DisplayPort, USB-C
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Raven black
Dimensions (WxDxH) - with stand 54.02 cm x 26.175 cm x 37.34 cm
Weight 5.69 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards FCC Class B certified, ISO 9241-307, WEEE, DDC-2B/CI, Directive 2002/95/EC, TCO Certified Edge 2.0, TCO Displays 7.0, China Energy standard Tier 2, VESA TMDS, TUV Rheinland Eye Comfort Certification
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Lenovo ThinkVision P24...
£239.73
