Lenovo ThinkVision P27q-20 27" 2560x1440 4ms HDMI Displa...
Lenovo ThinkVision P27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor
£355.06
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 4ms
  • Interfaces: DisplayPort, HDMI, Mini DisplayPort
  • Stock Status: In Stock
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £358.55
Save £1.50
The ThinkVision P27q monitor has a black glossy appearance with a full function ergonomic stand. It offers a crystal clear borderless IPS display of 2560x1440 resolution and sRGB 99% color gamut, providing vivid, accurate images from a wide viewing angle. Moreover, each monitor has been pre-calibrated to obtain an accurate and consistent color with a factory calibration report. With built-in power and the rich connectivity of 2HDMI, DP, mDP and DP out, P27q satisfies diverse connection demand and can make multi-screen easier with daisy chain. P27q also has 4 USB3.0 ports, including 1 with BC1.2, which offers quick charge to your USB devices. Its full function stand supports lift, tilt, pivot and swivel, which are all for your ease of use.
Product Description Lenovo ThinkVision P27q-20 - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Features USB 3.1 Gen 1 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440
Pixel Pitch 0.2331 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 3000000:1 (dynamic)
Response Time 6 ms (normal); 4 ms (extreme)
Colour Support 16.7 million colours
Input Connectors HDMI, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Raven black
Dimensions (WxDxH) - with stand 61.38 cm x 20.8 cm x 44.15 cm
Weight 7.12 kg
Localisation English / United Kingdom
Environmental Standards TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Silver
Compliant Standards CCC, RoHS, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Lenovo ThinkVision P27...
£355.06
