We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Offering a stunning visual experience, the ThinkVision P44w-10 allows you to be more productive every day. The 43.4-inch large screen real estate and the wide viewing angle make content creation and consumption exceptional. The versatile connectivity ports expand your device capabilities by enabling easy connection to other peripherals. Packed with advanced features, this monitor is your perfect canvas to amplify productivity.
Product Description | Lenovo ThinkVision P44w-10 - LED monitor - curved - 43.4" - HDR | Device Type | LED-backlit LCD monitor - 43.4" | Energy Class | Class G | Power Consumption (On mode) | 49 W | Curved Screen | Yes | Features | USB 3.1 hub | Panel Type | VA | Aspect Ratio | 32:10 | Native Resolution | 3840 x 1200 at 144 Hz | Pixel Pitch | 0.274 mm | Brightness | 450 cd/m² | Contrast Ratio | 3000:1 / 3000000:1 (dynamic) | HDR Capable | DisplayHDR 400 | Response Time | 4 ms (extreme), 6 ms (typical) | Colour Support | 1.07 billion colours | Colour Gamut | 99.5% BT.709, 99.5% sRGB, 90% DCI-P3 | Input Connectors | 2xHDMI, DisplayPort, 2xUSB-C | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Raven black | Dimensions (WxDxH) - with stand | 1.0583 m x 26.98 cm x 46.11 cm | Weight | 13.45 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | CCC, RoHS, DisplayPort 1.2, China Energy standard Tier 2, TUV Rheinland Eye Comfort Certification, DisplayPort 1.4, ULE Gold | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 43.4" |
Curved Screen | Yes (1800R) |
Built-in Devices | USB 3.1 hub |
Panel Type | VA |
Pixel Per Inch | 93 |
HDR Certification | DisplayHDR 400 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | PIP 2.0, PBP, 178° viewing angle, NearEdgeless |
Dimensions (WxDxH) | 1.0583 m x 26.98 cm x 46.11 cm - with stand |
Weight | 13.45 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 4 Watt |
Connectivity | |
Interfaces | DisplayPort , 2 x HDMI , 4 x USB 3.1 Gen 1 downstream , USB-C 3.1 Gen 1 upstream/DisplayPort Alt Mode , USB-C 3.1 Gen 2 upstream/DisplayPort Alt Mode , Audio line-out (mini-jack) |
Mechanical | |
Tilt Angle | -5/+22 |
Swivel Angle | 60 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), integrated cable management |
Cables Included | 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB 3.1 Gen 2 cable - 1.5 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 49 kWh/1000h |
Power Consumption HDR (On mode) | 80 kWh/1000h |
Power Consumption (Typical) | 70 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Software / System Requirements | |
Included Software | ThinkColor |
OS Required | Microsoft Windows 7 / 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 1.0583 m - depth: 26.98 cm - height: 46.11 cm - weight: 13.45 kg , Without stand - width: 1.0583 m - depth: 13.72 cm - height: 36.61 cm - weight: 9.35 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 1.219 m |
Shipping Depth | 37.6 cm |
Shipping Height | 50 cm |
Shipping Weight | 18.59 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 7.1 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
