ThinkVision S22e-20 gives users the fine detail they need while working out the small print on long contracts or inputting data for long periods. With 3-side NearEdgeless design, more of the monitor is dedicated to the screen with bulky bezels trimmed down to the minimum, allowing you to create a cleaner experience on your people's workstations. The monitor elevates its performance, as it sits higher on its stand. The stand also tilts to create even better angles conducive to each individual's work. Plus, with improved flexible cable management, it's much easier to tidy power cords off the desk and out of the way. And there's a bonus clutter-free feature here: Users will love the phone holder built into its stylish square base. Getting the right tools for staff also means managing their comfort and well-being. That's why S22e-20 cuts down harmful blue wavelengths that can lead to eye fatigue.
Product Description | Lenovo ThinkVision S22e-20 - LED monitor - Full HD (1080p) - 21.5" | Device Type | LED-backlit LCD monitor - 21.5" | Energy Class | Class E | Power Consumption (On mode) | 16 W | Adaptive-Sync Technology | AMD FreeSync | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 3000000:1 (dynamic) | Response Time | 4 ms (extreme), 6 ms (typical) | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Voltage | AC 100-240 V (50/60 Hz) | Colour | Raven black | Dimensions (WxDxH) - with stand | 48.93 cm x 17.31 cm x 40.51 cm | Weight | 3.14 kg | Localisation | English / United Kingdom | Environmental Standards | TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Gold | Compliant Standards | RoHS, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, China Energy standard Tier 2 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 21.5" |
Panel Type | VA |
Pixel Per Inch | 102 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | Anti-glare, 3-sided bezeless, 72% NTSC colour gamut |
Dimensions (WxDxH) | 48.93 cm x 17.31 cm x 40.51 cm - with stand |
Weight | 3.14 kg |
Connectivity | |
Interfaces | HDMI , VGA (HD-15) , Headphones |
Mechanical | |
Tilt Angle | -5/+22 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), integrated cable management |
Cables Included | 1 x HDMI cable - 1.8 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 16 kWh/1000h |
Power Consumption (Typical) | 15 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
OS Required | Microsoft Windows 7 / 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 48.93 cm - depth: 17.31 cm - height: 40.51 cm - weight: 3.14 kg , Without stand - width: 48.93 cm - depth: 4.55 cm - height: 29.68 cm - weight: 2.39 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 58.7 cm |
Shipping Depth | 14 cm |
Shipping Height | 35.2 cm |
Shipping Weight | 4.68 kg |
Sustainability Information | |
TCO Certified | TCO Certified Displays 8, TCO Certified Edge Displays |
EPEAT Compliant | EPEAT Gold |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 8.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
