The 21.5" S22e-19 ThinkVision monitor with 178° wide viewing angle displays clearer images across the screen, and the flicker-free display reduces motion blur on fast-moving videos. Ideal for any kind of office environment, this monitor boosts productivity with versatile connectivity options, TÜV Low Blue Light certification, and a quick-release tilt stand for comfortable working modes.
Product Description | Lenovo ThinkVision S22e-19 - LED monitor - Full HD (1080p) - 21.5" | Device Type | LED-backlit LCD monitor - 21.5" | Energy Class | Class D | Power Consumption (On mode) | 11.5 W | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 3000000:1 (dynamic) | Response Time | 4 ms (extreme), 6 ms (typical) | Colour Support | 16.7 million colours | Colour Gamut | 72% | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Raven black | Dimensions (WxDxH) - with stand | 48.93 cm x 20 cm x 37.38 cm | Weight | 2.75 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | CCC, EMC, FCC, DDC/CI, RoHS, WEEE, TUV Rheinland Low Blue Light Certification, China Energy standard Tier 2, VESA TMDS | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 21.5" |
Panel Type | VA |
Pixel Per Inch | 102 |
Vertical Refresh Rate | 49 - 76 Hz |
Horizontal Refresh Rate | 54 - 90 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | Anti-glare |
Dimensions (WxDxH) | 48.93 cm x 20 cm x 37.38 cm - with stand |
Weight | 2.75 kg |
Connectivity | |
Interfaces | HDMI , VGA (HD-15) , Headphones |
Mechanical | |
Tilt Angle | -5/+22 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), integrated cable management |
Cables Included | 1 x HDMI cable - 1.8 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 11.5 kWh/1000h |
Power Consumption (Typical) | 18 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
OS Required | Microsoft Windows 7 / 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 48.93 cm - depth: 20 cm - height: 37.83 cm - weight: 2.75 kg , Without stand - width: 48.93 cm - depth: 4.15 cm - height: 29.68 cm - weight: 2.46 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 58.2 cm |
Shipping Depth | 12 cm |
Shipping Height | 35 cm |
Shipping Weight | 4.07 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 7.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
