Lenovo ThinkVision S27i-10 27" 1920x1080 6ms VGA HDMI IP...
Lenovo ThinkVision S27i-10 27" 1920x1080 6ms VGA HDMI IPS LED Monitor
£180.91
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 27in
  • Max Resolution: 1920 x 1080
  • Response Time: 6ms
  • Interfaces: HDMI, VGA (HD-15)
  • Stock Status: In Stock
Product codes
The ThinkVision S27i-10 is a high-performance monitor specifically meant for your work in the office. With a 27-inch FHD In-Plane Switching display, enjoy a 178° wide viewing angle with crystal-clear detail and vivid colours. The excellent display performance and functions also optimise your working experience.
With the bezel width (side) being just 2.0 mm, the Near Edgeless FHD In-Plane Switching display offers an effective solution for a multi-display connection, enabling a seamless visual experience. The multiple ports include VGA and HDMI, which lets you expand your capabilities. Choose where you want your monitor; on a tilt-stand or on the wall. Eye Comfort certification by TÜV ensures these displays are easy on the eyes, allowing you to play much more.
Product Description Lenovo ThinkVision S27i-10 - LED monitor - Full HD (1080p) - 27"
Device Type LED-backlit LCD monitor - 27"
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch 0.311 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 3000000:1 (dynamic)
Response Time 6 ms (typical); 4 ms (extreme)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA
Display Position Adjustments Tilt
Colour Raven black
Dimensions (WxDxH) - with stand 61.19 cm x 22 cm x 44.35 cm
Weight 4.76 kg
Localisation English / United Kingdom
Environmental Standards TCO Certified Displays 7, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards DDC/CI, RoHS, China Energy standard Tier 2, VESA TMDS, TUV Rheinland Eye Comfort Certification
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Lenovo ThinkVision S27...
£180.91
