We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The Lenovo ThinkVision T23d-10 is a superior monitor that is meant to take your efficiency to new heights. With the vivid 22.5-inch display and versatile connectivity options, the ThinkVision T23d-10 lets you perform with your full potential.
The 16:10 aspect ratio of the T23d-10 monitor makes for an extra wide display and a superior viewing experience. The borderless panel of the bright WUXGA monitor and the super narrow bezel make it ideal for multi-screen connection, adding to your productivity. With up to 4ms response time, the anti-glare display minimizes motion blur and eliminates streaking and ghosting for a smooth interaction. The ThinkVision T23d-10 has a range of ports such as VGA, DP, and HDMI to boost productivity.
Product Description | Lenovo ThinkVision T23d-10 - LED monitor - 22.5" | Device Type | LED-backlit LCD monitor - 22.5" | Energy Class | Class D | Panel Type | IPS | Aspect Ratio | 16:10 | Native Resolution | WUXGA 1920 x 1200 | Pixel Pitch | 0.25 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 6 ms | Colour Gamut | 72% | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 50.12 cm x 25.19 cm x 49.19 cm | Weight | 4.85 kg | Localisation | English / United Kingdom | Environmental Standards | TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified | Compliant Standards | FCC Class B certified, RoHS, ISO 9241-307, WEEE, DDC-2B/CI | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22.5" |
Panel Type | IPS |
Pixel Per Inch | 100.6 |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | WLED |
Features | HDCP |
Colour | Black |
Weight | 4.85 kg |
Connectivity | |
Interfaces | VGA , HDMI (HDCP) , DisplayPort (HDCP) |
Mechanical | |
Tilt Angle | -5/+30 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 110 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , Power cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 13.9 kWh/1000h |
Power Consumption (Typical) | 15 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
Software / System Requirements | |
OS Required | Microsoft Windows 7 / 10 |
Dimensions & Weight | |
Dimensions & Weight Details | Width: 50.12 cm - depth: 25.19 cm - height: 49.19 cm - weight: 4.85 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8, TCO Certified Edge Displays |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Limited warranty - backlight - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
