We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The ThinkVision T23i-10 monitor has concise appearance with a full function ergonomic stand. It offers a clear display with near edgeless IPS type screen, providing vivid images from a wide viewing angle. With built-in power and the rich connectivity of VGA, HDMI and DP, T23i-10 satisfies diverse connection demand.
Product Description | Lenovo ThinkVision T23i-10 - LED monitor - Full HD (1080p) - 23" | Device Type | LED-backlit LCD monitor - 23" | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.265 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 3000000:1 (dynamic) | Response Time | 6 ms | Colour Gamut | 72% | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Raven black | Dimensions (WxDxH) - with stand | 52.22 cm x 26.42 cm x 33.77 cm | Weight | 5.15 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | RoHS, China RoHS, China Energy standard Tier 2, TUV Rheinland Eye Comfort Certification | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Chinese (simplified), English, German, French, Italian, Russian, Spanish, Japanese |
Features | HDCP, anti-glare |
Dimensions (WxDxH) | 52.22 cm x 26.42 cm x 33.77 cm - with stand |
Weight | 5.15 kg |
Connectivity | |
Interfaces | VGA , HDMI , DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out |
Mechanical | |
Tilt Angle | -5/+30 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 110 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), PVC free, arsenic free |
Cables Included | 1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 16 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Software / System Requirements | |
OS Required | Microsoft Windows 7 / 10 |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 52.22 cm - depth: 4.27 cm - height: 31.76 cm - weight: 3.25 kg , With stand - width: 52.22 cm - depth: 26.42 cm - height: 33.77 cm - weight: 5.15 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - 3 years - carry-in |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
