We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
There's no need to compromise performance and functionality for cost. The affordable Lenovo ThinkVision T24m has it all - 23.8" of Full HD near-edgeless display for outstanding images and crisp text from center to sides, along with convenient one-cable solution USB Type C and broad connectivity. It is ideal for enterprise and home, office, also features full-function, ergonomic stand and TüV certification to optimize your use experience.
Product Description | Lenovo ThinkVision T24m-10 - LED monitor - Full HD (1080p) - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class E | Power Consumption (On mode) | 15 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.2745 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 3000000:1 (dynamic) | Response Time | 6 ms | Colour Gamut | 99% sRGB | Input Connectors | HDMI, DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 54.02 cm x 26.175 cm x 37.34 cm | Weight | 5.6 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | FCC Class B certified, RoHS, ISO 9241-307, WEEE, DDC-2B/CI, UL Environmental SPC Gold, DisplayPort 1.2, China Energy standard Tier 2 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Pixel Per Inch | 92 |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | +85 / -85 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | WLED |
OSD Languages | English, German, French, Italian, Russian, Spanish, Japanese, Chinese |
Features | HDCP, Mercury free, arsenic free, 99% sRGB colour gamut |
Colour | Black |
Dimensions (WxDxH) | 54.02 cm x 26.175 cm x 37.34 cm - with stand |
Weight | 5.6 kg |
Connectivity | |
Interfaces | HDMI (HDCP) , DisplayPort (HDCP) , USB-C , Audio line-out , USB 3.0 upstream , 4 x USB 3.0 downstream |
Mechanical | |
Tilt Angle | -5/+30 |
Swivel Angle | 90 |
Height Adjustment | 110 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), integrated cable management, detachable stand |
Cables Included | 1 x USB-C cable - 1.8 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 15 kWh/1000h |
Power Consumption (Typical) | 17 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 54.02 cm - depth: 26.175 cm - height: 37.34 cm - weight: 5.6 kg , Without stand - width: 54.02 cm - depth: 4.645 cm - height: 32.598 cm - weight: 3.73 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Limited warranty - backlight - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
