We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The ThinkVision T25m 25-inch monitor with a 16:10 aspect ratio, offers 8% larger display area than a traditional 24-inch 16:10 monitor, perfect for commercial users who need additional screen real estate. Engineered to produce lifelike visuals, the WUXGA 1920 x 1200 resolution display offers remarkable clarity. Modern connectivity options on the T25m enable easy collaboration along with performance. The USB Type-C cable and integrated speakers combo offers an impressive audio-visual experience. The ergonomic built provides optimum user comfort. With a NearEdgeless screen and smart, productivity-boosting features, the ThinkVision T25m is the next-generation display.
Product Description | Lenovo ThinkVision T25m-10 - LED monitor - 25" | Device Type | LED-backlit LCD monitor - 25" | Energy Class | Class F | Power Consumption (On mode) | 22.5 W | Features | USB 3.1 Gen 1/USB-C hub | Panel Type | IPS | Aspect Ratio | 16:10 | Native Resolution | 1920 x 1200 | Pixel Pitch | 0.2823 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 3000000:1 (dynamic) | Response Time | 4 ms (extreme), 6 ms (typical) | Colour Support | 16.7 million colours | Colour Gamut | 99% sRGB | Input Connectors | HDMI, DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 100 - 240 V (50 - 60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 54.87 cm x 26.04 cm x 50.95 cm | Weight | 5.5 kg | Localisation | English / United Kingdom | Environmental Standards | TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified | Compliant Standards | CCC, UL Environmental SPC Gold, China Energy standard Tier 2, TUV Rheinland Eye Comfort Certification, EU RoHS, ULE Gold | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 25" |
Built-in Devices | USB 3.1 Gen 1/USB-C hub |
Panel Type | IPS |
Pixel Per Inch | 91 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | 99% sRGB colour gamut |
Colour | Black |
Dimensions (WxDxH) | 54.87 cm x 26.04 cm x 50.95 cm - with stand |
Weight | 5.5 kg |
Connectivity | |
Interfaces | HDMI , DisplayPort , USB-C upstream , 4 x USB 3.1 Gen 1 , Audio line-out |
Mechanical | |
Tilt Angle | -5/+30 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 110 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x USB cable - 1.8 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100 - 240 V (50 - 60 Hz) |
Power Consumption SDR (On mode) | 22.5 kWh/1000h |
Power Consumption (Typical) | 30 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
OS Required | Microsoft Windows 7, Windows 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 54.87 cm - depth: 26.04 cm - height: 50.95 cm - weight: 5.5 kg , Without stand - width: 54.87 cm - depth: 4.3 cm - height: 36.91 cm - weight: 3.58 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8, TCO Certified Edge Displays |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
