Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPor...
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor
£482.41
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • With the In-Plane Switching technology and UHD resolution with 1.07 billion colors, you are assured of crystal-clear picture quality, more natural colors, and wider viewing angles
  • 4ms response time to minimize motion blur caused by fast-moving images for a superior visual experience
  • Eliminate cable clutter with a single, all-in-one data, video, and power connector - the USB Type-C
  • Reduce the strain on your back and neck with a fully ergonomic monitor stand
  • Protect your eyes from blue light emission with the TÜV Eye Comfort certified anti-glare screen
  • Diagonal Size: 27in
  • Max Resolution: 3840 x 2160
  • Response Time: 4ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, USB-C
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £485.90
Save £1.50
The ThinkVision T27p is designed to provide you with a spectacular viewing experience. The NearEdgeless screen and 3840 x 2160 resolution make it an excellent productivity tool. The USB Type-C port provides a perfect one-cable solution by transiting data, video, and providing power delivery to compatible devices. Multiple USB ports enable easy connectivity to peripherals, making it a truly great investment for professionals in any industry who rely on additional monitors to multitask. Moreover, the ergonomically designed stand with lift, tilt, pivot, and swivel functionalities allows you to adjust the monitor for your comfort.
Product Description Lenovo ThinkVision T27p-10 - LED monitor - 4K - 27"
Device Type LED-backlit LCD monitor - 27"
Features USB 3.1 Gen 1 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160
Pixel Pitch 0.1554 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 3000000:1 (dynamic)
Response Time 14 ms (grey-to-grey); 6 ms; 4 ms (extreme)
Colour Support 1.07 billion colours
Input Connectors HDMI, DisplayPort, USB-C
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Dimensions (WxDxH) - with stand 61.16 cm x 21 cm x 40.33 cm
Weight 6.95 kg
Localisation English / United Kingdom
Environmental Standards TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards CCC, RoHS, UL Environmental SPC Gold, China Energy standard Tier 2, TUV Rheinland Eye Comfort Certification
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Lenovo ThinkVision T27...
£482.41
