Do more than just optimize your productivity with the ThinkVision T32h-20 monitor. Get an enhanced view of and easily navigate through documents, spreadsheets, or designs on this sleek display that complements your modern workspace. Its vast 31.5-inch screen with QHD resolution delivers more screen real estate with higher clarity than FHD, making data-intensive work, number crunching, and content editing a breeze. The one-cable solution USB Type-C, HDMI, and DP ports provide multiple interface options. Integrated with Smart Power the USB Type-C also doubles up as a charger for dynamic consumption and intelligent power management.
Product Description | Lenovo ThinkVision T32h-20 - LED monitor - 32" | Device Type | LED-backlit LCD monitor - 32" | Energy Class | Class E | Power Consumption (On mode) | 26.5 W | Features | USB 3.1 Gen 1 hub, USB PD 75 Watt | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | QHD 2560 x 1440 | Pixel Pitch | 0.2727 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 / 3000000:1 (dynamic) | Response Time | 14 ms, 6 ms, 4 ms (extreme mode) | Colour Support | 1.07 billion colours | Colour Gamut | 99% sRGB | Input Connectors | HDMI, DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Raven black | Dimensions (WxDxH) - with stand | 71.46 cm x 23.5 cm x 46.94 cm | Weight | 9.85 kg | Localisation | English / United Kingdom | Environmental Standards | TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Silver | Compliant Standards | CCC, RoHS, DisplayPort 1.2, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 32" |
Built-in Devices | USB 3.1 Gen 1 hub |
USB Power Delivery | 75 Watt |
Panel Type | IPS |
Pixel Per Inch | 94 |
Vertical Refresh Rate | 60 Hz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | Integrated cable management, 3-side NearEdgeless, 99% sRGB colour gamut |
Dimensions (WxDxH) | 71.46 cm x 23.5 cm x 46.94 cm - with stand |
Weight | 9.85 kg |
Connectivity | |
Interfaces | DisplayPort , HDMI , Headphones , USB 3.1 Gen 1 downstream with Battery Charging , 3 x USB 3.1 Gen 1 downstream , USB-C 3.1 Gen 1 upstream/DisplayPort Alt Mode with Power Delivery (power up to 75W) |
Mechanical | |
Tilt Angle | -5/+35 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 135 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x USB-C cable - 1.8 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 26.5 kWh/1000h |
Power Consumption (Typical) | 28 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand (highest position) - width: 71.46 cm - depth: 23.5 cm - height: 60.44 cm - weight: 9.85 kg , With stand (lowest position) - width: 71.46 cm - depth: 23.5 cm - height: 46.94 cm - weight: 9.85 kg , Without stand - width: 71.46 cm - depth: 5.1 cm - height: 42.6 cm - weight: 6.78 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 84.5 cm |
Shipping Depth | 52.8 cm |
Shipping Height | 19 cm |
Shipping Weight | 12.96 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8, TCO Certified Edge Displays |
EPEAT Compliant | EPEAT Silver |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 8.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
