We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Product Description | Lenovo ThinkVision X1 - Gen 2 - LED monitor - 4K - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class G | Power Consumption (On mode) | 32.1 W | Features | Microphone, USB 3.0 hub, FHD camera with LED light | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 | Pixel Pitch | 0.1554 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 / 3000000:1 (dynamic) | Response Time | 4 ms, 6 ms, 14 ms (grey-to-grey) | Colour Gamut | 99% sRGB | Input Connectors | HDMI, DisplayPort, Thunderbolt 3 | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 60.974 cm x 3.27 cm x 35.171 cm | Weight | 4.29 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | UL, RoHS, China Energy standard Tier 2 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | USB 3.0 hub, FHD camera with LED light |
Panel Type | IPS |
Pixel Per Inch | 163 |
Vertical Refresh Rate | 23 - 80 Hz |
Horizontal Refresh Rate | 30 - 60 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Colour Temperature | 6500K |
OSD Languages | English, German, French, Italian, Russian, Spanish, Japanese, Chinese |
Features | Anti-glare, Mercury free, arsenic free, 99% sRGB colour gamut |
Colour | Black |
Weight | 4.29 kg |
Audio | |
Type | Speakers |
Input | |
Type | Microphone |
Connectivity | |
Interfaces | HDMI , DisplayPort , Headphone/microphone combo jack , USB-C , 4 x USB 3.0 downstream , Thunderbolt |
Mechanical | |
Tilt Angle | -5/+30 |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x HDMI cable - 1.8 m , 1 x Thunderbolt cable - 1.8 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 32.1 kWh/1000h |
Power Consumption (Typical) | 65 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Software / System Requirements | |
OS Required | Microsoft Windows 7 / 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 60.974 cm - depth: 12.305 cm - height: 23.481 cm - weight: 5.59 kg , Without stand - width: 60.974 cm - depth: 3.27 cm - height: 35.171 cm - weight: 4.29 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 8 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
