Lenovo Tiny-in-One 22 21.5" 1920 x 1080 14ms Full HD LED...
Lenovo Tiny-in-One 22 21.5" 1920 x 1080 14ms Full HD LED monitor
£292.51
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Borderless panel with 1920 x 1080 resolution
  • Built-in camera with ThinkShutter
  • Supports USB-A 3.2 Gen 1, Display Port, and USB-B
  • Diagonal Size: 21.5in
  • Max Resolution: 1920 x 1080
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort
Product codes
Create an all-in-one PC using this 21.5" Full HD display, which is compatible with any ThinkCentre Tiny. The ThinkCentre Tiny simply inserts into the dedicated compartment behind the screen, enabling the PC to be upgraded independently of the display. Integrated web conferencing features include an adjustable webcam and speakers.
Product Description Lenovo ThinkCentre Tiny-in-One 22 Gen 4 - LED monitor - Full HD (1080p) - 21.5"
Device Type LED-backlit LCD monitor - 21.5"
Features USB 3.1 Gen 1 hub, 720p camera with dual microphone and Think Shutter
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.24795 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 6 ms, 4 ms (overdrive), 14 ms (default)
Colour Gamut 72% NTSC (CIE 1931)
Input Connectors DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Voltage AC 120/230 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) - with stand (lowest position) 48.93 cm x 22.04 cm x 41.82 cm
Weight 6.58 kg
Localisation EMEA
Environmental Standards ENERGY STAR Qualified EPEAT Silver
Compliant Standards UL, VESA FPMPMI, RoHS, WEEE, GREENGUARD, Energy-Related Products (ErP) Lot 5, TUV Rheinland Eye Comfort Certification
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£292.51
