Keep a spare ThinkPad 90 W AC Adapter to hand to ensure your ThinkPad has a consistent flow of power. Keep one in the office, one at home and another in your carrying case for immediate, convenient access to power. This ThinkPad AC adapter is perfect for use as a spare or replacement adapter for compatible laptops. It is compatible with all Lenovo laptops with the rectangular "slim-tip" common power plug. It is not compatible with legacy notebook systems with the round, barrel-type power plug. ThinkPad AC adapters are compact so you can easily keep a spare tucked into your carrying case at all times. This 90 W adapter will perform to the exact same standard as the one which originally came with your laptop. It is highly energy efficient and is backed by an official Lenovo one-year warranty.
Product Description | Lenovo ThinkPad 90W AC Adapter (Slim Tip) - power adapter - 90 Watt | Device Type | Power adapter - external | Weight | 360 g | Localisation | Saudi Arabia, Hong Kong, Singapore, United Kingdom | Input Voltage | AC 100-240 V | Power Capacity | 90 Watt | Output connectors | 1 x power DC jack | Dimensions (WxDxH) | 5 cm x 12.6 cm x 3 cm | Manufacturer Warranty | 1-year warranty | Designed For | B40-30; B40-70; B40-80; M5400; ThinkPad 11; 11e Chromebook; Thinkpad 13; ThinkPad A275; A475; E46X; E47X; E56X; E57X; L460; L470; L560; L570; P40 Yoga; P50s; P51s; T25; T460; T470; T560; T570; X1 Carbon; X1 Yoga; X260; X270; ThinkPad Yoga 11; 11e Chromebook; 14; 260; 370; 460; V330-14; V330-15; V720 |
General | |
Power Device | |
Frequency Required | 50/60 Hz |
Power Output Connectors Details | 1 x power DC jack |
Miscellaneous | |
Cables Included | Power cable |
Compliant Standards | UL, C-Tick, BSMI, GOST, cUL, NEMKO, NOM, CB, CCC, EMC, PSB, FCC, PSE Mark, ICES, S Mark |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - 1 year |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 8 - 80% (non-condensing) |
Dimensions & Weight | |
Width | 5 cm |
Depth | 12.6 cm |
Height | 3 cm |
Weight | 360 g |
Compatibility Information | |
Designed For | Lenovo 330-15IKB 81FE , Lenovo ThinkPad 11e (3rd Gen) 20G8, 20G9, 20GB , Lenovo ThinkPad 11e (4th Gen) 20HT, 20HV , Lenovo ThinkPad 11e (5th Gen) 20LQ, 20LR , Lenovo ThinkPad 11e Chromebook (3rd Gen) 20GD, 20GF , Lenovo ThinkPad 11e Chromebook (4th Gen) 20J0 , Lenovo Thinkpad 13 (1st Gen) 20GJ, 20GK , Lenovo Thinkpad 13 (2nd Gen) 20J1, 20J2 , Lenovo ThinkPad A275 20KC, 20KD , Lenovo ThinkPad A475 20KL, 20KM , Lenovo ThinkPad E460 20ET, 20EU , Lenovo ThinkPad E465 20EX , Lenovo ThinkPad E470 20H1, 20H2 , Lenovo ThinkPad E475 20H4 , Lenovo ThinkPad E560 20EV, 20EW , Lenovo ThinkPad E560p 20G4, 20G5 , Lenovo ThinkPad E565 20EY , Lenovo ThinkPad E570 20H5, 20H6 , Lenovo ThinkPad E575 20H8 , Lenovo ThinkPad L460 20FU, 20FV , Lenovo ThinkPad L470 20J4, 20J5, 20JU, 20JV , Lenovo ThinkPad L560 20F1, 20F2 , Lenovo ThinkPad L570 20J8, 20J9, 20JQ, 20JR , Lenovo ThinkPad P40 Yoga 20GQ, 20GR , Lenovo ThinkPad P50s 20FK, 20FL , Lenovo ThinkPad P51s 20HB, 20HC, 20JY, 20K0 , Lenovo ThinkPad T25 20K7 , Lenovo ThinkPad T460 20FM, 20FN , Lenovo ThinkPad T460p 20FW, 20FX , Lenovo ThinkPad T460s 20F9, 20FA , Lenovo ThinkPad T470 20HD, 20HE, 20JM, 20JN , Lenovo ThinkPad T470p 20J6, 20J7 , Lenovo ThinkPad T470s 20HF, 20HG, 20JS, 20JT , Lenovo ThinkPad T560 20FH, 20FJ , Lenovo ThinkPad T570 20H9, 20HA, 20JW, 20JX , Lenovo ThinkPad X1 Carbon (4th Gen) 20FB, 20FC , Lenovo ThinkPad X1 Yoga (1st Gen) 20FQ, 20FR , Lenovo ThinkPad X260 20F5, 20F6 , Lenovo ThinkPad X270 20HM, 20HN, 20K5, 20K6 , Lenovo ThinkPad Yoga 11e (3rd Gen) 20G8, 20GA , Lenovo ThinkPad Yoga 11e (4th Gen) 20HS, 20HU , Lenovo ThinkPad Yoga 11e (5th Gen) 20LM, 20LN , Lenovo ThinkPad Yoga 11e Chromebook (3rd Gen) 20GC, 20GE , Lenovo ThinkPad Yoga 260 20FD, 20FE, 20GS, 20GT , Lenovo ThinkPad Yoga 370 20JH, 20JJ , Lenovo ThinkPad Yoga 460 20EL, 20EM , Lenovo V330-14IKB 81B0 , Lenovo V330-14ISK 81AY , Lenovo V330-15IKB 81AX , Lenovo V330-15ISK 81AW , Lenovo V720 80Y1 |
