Lenovo TP X200 SERIES 6 CELL LI-ION BATTERY
£72.31
Delivery:
Key features
  • Lithium-Ion (Li-Ion) technology
  • Six-cell, rechargeable system battery
  • Standard system battery specifications
  • Over-discharge protection
Product codes
The Lenovo ThinkPad battery 47+ allows you to increase the capacity of your 4-cell system battery on selected models or extend your unplugged computing time by carrying a spare. It is compatible with the X200 and X201 systems, and the design allows it to be in a system connected to the ThinkPad X200 UltraBase. The 6-cell, rechargeable battery utilises advanced Lithium Ion (Li-Ion) technology to create an efficient and balanced power source. The current is 10.8 volts and 5.2 ampere hours. The over-discharge protection safeguards against incorrect voltage and ensures a safe flow of power.
*Battery life varies due to many factors. These include: applications, battery conditioning, features, power management, screen brightness and other customer preferences. For more battery life information, go to lenovo.com/alldaycomputing.
Product Description Lenovo - laptop battery - Li-Ion - 5200 mAh
Device Type Laptop battery
Weight 330 g
Battery Lithium Ion 6-cell - 5200 mAh
Batteries Qty 1
Dimensions (WxDxH) 20.8 cm x 5.3 cm x 2 cm
Manufacturer Warranty 1-year warranty
Designed For ThinkPad X200; X200s; X200si; X201; X201i; X201s
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Lenovo TP X200 SERIES...
£72.31
