Lenovo USB 3.0 to DVI/VGA Monitor Adapter
£58.46
27 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Attach up to six adapters on one system
  • Attach VGA analog or Digital DVI monitor, projector
  • Plug and Play
  • Hot plug; attach or detach monitor without system reboot
  • Resumes from hibernation and suspend modes
  • 16 and 32-bit color depth supported at all monitor resolutions
  • Stock Status: In Stock
Product codes
USB is ubiquitous. The Lenovo USB 3.0 to DVI/VGA Monitor Adapter (0B47072) provides a quick and easy way to attach an analog or digital monitor to a ThinkPad or ThinkCentre USB port, helping to increase productivity through the use of multiple monitors.
The Lenovo USB 3.0 to DVI/VGA Monitor Adapter is ideal for increasing the efficiency of everyday tasks. View and extend spreadsheets across multiple monitors, or view financial charts simultaneously. Using multiple USB 3.0 to DVI/VGA Monitor Adapters reduces overlapping of windows when multitasking is required, and increases overall user experience and productivity. Adapters coexist with existing system monitor ports and installed graphics cards.
Product Description Lenovo USB 3.0 to DVI/VGA Monitor Adapter - external video adapter
Device Type External video adapter
Bus Type SuperSpeed USB 3.0
Max Resolution 2048 x 1152
Interfaces DVI-I , VGA - with adapter
Dimensions (WxDxH) 5 cm x 8 cm x 2.5 cm
Manufacturer Warranty 1-year warranty
Designed For IdeaPad 3 14ARE05; 3 15ARE05; 3 17ARE05; ThinkPad E14 Gen 2; E15 Gen 2; L14 Gen 1; L15 Gen 1; P1 (3rd Gen); P14s Gen 1; P15 Gen 1; P15s Gen 1; P15v Gen 1; P17 Gen 1; T14 Gen 1; T14s Gen 1; T15 Gen 1; T15p Gen 1; X1 Carbon Gen 8; X1 Extreme Gen 3; X1 Yoga Gen 5; X13 Gen 1; X13 Yoga Gen 1; V14
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Lenovo USB 3.0 to DVI/...
£58.46
