Lenovo USB-C Laptop Power Bank-WW
£89.95
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Bring extra power when you're on the move! Compatible with Lenovo and ThinkPad Slim-tip and USB-C powered notebooks, the Lenovo USB-C Laptop Power Bank provides 48 Wh battery life (14000 mAh) to extend your notebook's life and your productivity. Featuring an additional two integrated USB-A ports, the Lenovo USB-C Laptop Power Bank powers small mobile devices. While perfectly portable, it also supports simultaneous charging – giving you the control to charge your notebook and power bank at the same time while on your workstations.
Product Description Lenovo Laptop Power Bank - external battery pack - 14000 mAh - 48 Wh
Device Type External battery pack
Weight 290 g
Output connectors 2 x 4 pin USB Type A - 5 V 2.1 A , 1 x 24 pin USB-C - 5 V 3 A
Battery - 14000 mAh - 48 Wh
Batteries Qty 1
Included Accessories USB-C to Slim Tip adapter
Colour Gun metal
Dimensions (WxDxH) 12.4 cm x 8.3 cm x 2.3 cm
Manufacturer Warranty 1-year warranty
Designed For Chromebook Flex 5 13IML05; IdeaPad 3 CB 11IGL05; IdeaPad Flex 3 CB 11IGL05; ThinkBook Plus IML 20; ThinkPad E14 Gen 2; E15 Gen 2; L14 Gen 1; L15 Gen 1; P14s Gen 1; P15s Gen 1; T14 Gen 1; T14s Gen 1; T15 Gen 1; X1 Carbon Gen 8; X1 Yoga Gen 5; X13 Gen 1; X13 Yoga Gen 1; Yoga Duet 7 13IML05
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: F3HK 042739
£60.16
product
Ref: F3HK 042739
Accessories
Packaging
Functional
Software
Manuals
£60.16
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Lenovo USB-C Laptop Po...
£89.95
