Quickly and securely transfer photos, videos, and files with the affordable, high-performance Lexar JumpDrive S75 USB 3.0 drive. It features a retractable connector with an easy-to-use thumb slide.
Product Description | Lexar JumpDrive S75 - USB flash drive - 256 GB | Product Type | USB flash drive | Interface Type | USB 3.0 | Storage Capacity | 256 GB | Encryption Algorithm | 256-bit AES | Enclosure Colour | White | Software Included | EncryptStick Lite | Manufacturer Warranty | 3-year warranty |
General | |
Compatibility | Non-specific |
Memory | |
Read Rate | Up to 150 MB/s |
Write Rate | Up to 60 MB/s |
Features | Retractable connector |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
