Lexar JumpDrive TwistTurn - USB flash drive - 64 GB - USB 2.0...
Lexar JumpDrive TwistTurn - USB flash drive - 64 GB - USB 2.0 - black
£10.50
22 left in stock
Delivery:
Standard: 1-3 working days
Key features
  • Durable rotating jacket with capless design
  • High-capacity portable storage-easily transfer, store, and share a large number of files
  • LED activity light blinks when it writes
  • Take data, photo, music, and video files wherever you go
  • Capacity: 64GB
  • Interface: USB 2.0
  • Stock Status: Clearance
Product codes
Lexar JumpDrive TwistTurn is a high-capacity USB flash drive that provides a convenient solution for storing, transferring, and sharing multimedia and more.
JumpDrive TwistTurn has a simple plug-and-play design that allows you to quickly and easily store files, so wherever you go, your information goes with you. Its durable hinged jacket rotates to easily access a USB port, and it sports an LED activity light that blinks during file transfer, so you know when the job is done. JumpDrive TwistTurn also works across platforms, giving you flexibility and ease of use.
Product Description Lexar JumpDrive TwistTurn - USB flash drive - 64 GB
Product Type USB flash drive
Interface Type USB 2.0
Storage Capacity 64 GB
Enclosure Colour Black
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Lexar JumpDrive TwistT...
£10.50
