Lexar Professional Workflow HR2 USB Hub
Key features
  • Transfer and back up images and video from multiple memory cards at once
  • Customize your workflow with an innovative, modular design
  • Offload your work, faster
  • Quickly back up large files
  • Simple setup and use
Product codes
The readers, storage drives, and hubs leverage USB 3.0 technology for high-speed performance, while the Professional Workflow HR2 hub is also designed to deliver next-generation Thunderbolt 2 speeds. Thunderbolt 2 technology gives photographers and videographers the power to quickly transfer 4K video and other large media files, at up to twice the speed of Thunderbolt and up to 4x the speed of USB 3.0 devices. The Professional Workflow HR2 hub is also backwards compatible with Thunderbolt and USB 2.0 (at slower speeds), while using the same cables and connectors.
Simply plug the readers or storage drives of choice into the hub and start transferring and archiving files. It's that easy. Also, the Professional Workflow HR2 hub provides two Thunderbolt 2 ports and one USB 3.0 port, making it easy to daisy-chain with your existing setup. Having two Thunderbolt 2 ports also allows you to place the hub anywhere in your lineup of other Thunderbolt devices to create a unique, customizable setup. The hubs help you eliminate cable clutter and take control of your workflow.
Lexar Professional Workflow HR2 - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Lexar Professional Wor...
