LG 22BK55WY 22" 1680x1020 5ms VGA DVI LCD Monitor
£123.19
Delivery:
Key features
  • Full HD IPS display
  • Ergonomics for perfect working conditions
  • Advanced tech design
  • Built-in power for orderly workspaces
Product codes
The IPS displays clear and accurate colors from all angles for advanced work, making the panel suitable for professionals. Also, IPS picture quality allows you to create outstanding output.
The monitors provide comfortable viewing with versatile screen height/tilt/pivot/swivel adjustments. You can customize the display for a personal, comfortable workstation depending on various contents or office tools.
LG 22BK55WY - LED monitor - 22"
LED-backlit LCD monitor - 22"
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.2821 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Anthracite dark
50.6 cm x 23.9 cm x 37.9 cm
4.7 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, TUV GS, NEMKO, SEMKO, EN 61000-3-3, EN55024, TUV Ergo, DDC/CI, RoHS, Directive 2006/95/CE, EN 60950-1:2006, EN61000-3-2:2006, EMC 2004/108/EC, EN55022:2006 Class B, DIN ISO 9241-307, TCO Displays 7.0, EPA 7.0
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 22BK55WY 22" 1680x1...
£123.19
