LG 22BK55WY 22" 1680x1020 5ms VGA DVI LCD Monitor
£123.19
Delivery:
Key features
  • Full HD IPS display
  • Ergonomics for perfect working conditions
  • Advanced tech design
  • Built-in power for orderly workspaces
  • Diagonal Size: 22in
  • Max Resolution: 1680 x 1050
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, VGA (HD-15)
Product codes
The IPS displays clear and accurate colors from all angles for advanced work, making the panel suitable for professionals. Also, IPS picture quality allows you to create outstanding output.
The monitors provide comfortable viewing with versatile screen height/tilt/pivot/swivel adjustments. You can customize the display for a personal, comfortable workstation depending on various contents or office tools.
Product Description LG 22BK55WY - LED monitor - 22"
Device Type LED-backlit LCD monitor - 22"
Features USB 2.0 hub
Panel Type TN
Aspect Ratio 16:10
Native Resolution 1680 x 1050 at 60 Hz
Pixel Pitch 0.2821 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Anthracite dark
Dimensions (WxDxH) - with stand 50.6 cm x 23.9 cm x 37.9 cm
Weight 4.7 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, CSA, UL, TUV GS, NEMKO, SEMKO, EN 61000-3-3, EN55024, TUV Ergo, DDC/CI, RoHS, Directive 2006/95/CE, EN 60950-1:2006, EN61000-3-2:2006, EMC 2004/108/EC, EN55022:2006 Class B, DIN ISO 9241-307, TCO Displays 7.0, EPA 7.0
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 22BK55WY 22" 1680x1...
£123.19
