LG 22M38A-B 21.5" 1920x1080 5ms VGA LED Monitor
Key features
  • Protect your eyes and view in comfort
  • Preset customized options with just a click
  • Customize your workspace for multitasking
  • Offers improved color vision to color weakness
Product codes
Flicker Safe and Reader Mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero. On screen control and the display presets allow you to easily customize monitor settings with a few clicks of a mouse.
LG 22M38A-B - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Input Connectors
VGA
50.85 cm x 18.67 cm x 38.65 cm
2.4 kg
Plug and Play, DDC/CI
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 22M38A-B 21.5" 1920...
