LG 22MK400H-B 22" 1920x1080 5ms VGA HDMI IPS LED Monitor
£83.85
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • High definition with accurate color
  • Clearer, smoother image
  • React faster to the action
  • Enemies have nowhere to hide
  • Easier user interface
  • Convenient and flexible
  • Diagonal Size: 22in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: HDMI, VGA (HD-15)
Product codes
Full HD resolution with IPS delivers brilliant images that pop with vibrant detail from any viewing angle. AMD FreeSync Technology and a dynamic refresh rate virtually eliminates screen tearing and stuttering to bring you seamless, fluid movement during high-res, fast-paced games.
Dynamic Action Sync mode allows you to instantly react to your opponents and attack them without any display lag. It synchronizes your senses with real-time scenes in fast-paced games by minimizing input lag.
Black Stabilizer gives you full visual clarity, even in games where you spend a lot of time in the dark. It synchronizes and brightens the darkest areas, so that you can find enemies hiding in the shadows and shoot first.
Product Description LG 22MK400H-B - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22"
Energy Class Class A
Energy Consumption per Year 29 kWh
Power Consumption (On mode) 20 W
Adaptive-Sync Technology AMD FreeSync
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch 0.2537 mm
Brightness 250 cd/m²
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA
Display Position Adjustments Tilt
Screen Coating Anti-glare, 3H Hard Coating
Dimensions (WxDxH) - with stand 55.6 cm x 18.2 cm x 42.1 cm
Weight 3.08 kg
Compliant Standards Plug and Play, FCC Class B certified, UL, TUV, VCCI, cUL, DDC/CI, ERP
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 22MK400H-B 22" 1920...
£83.85
