LG 24BK550Y 24" 1920x1080 5ms VGA DVI HDMI DisplayPort L...
£151.20
Delivery:
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
Product codes
FULL HD IPS DISPLAY
Designed for professionals, this Full HD display with IPS technology minimizes color shifts and provides outstanding picture quality from virtually any viewing angle.
INTEGRATED POWER MODULE FOR ORGANIZED WORKSPACES
The power module is integrated with the monitor, helping to reduce the amount of power modules in your workspace.
PERSONALIZED VIEWING ANGLES AND EASY ASSEMBLY
The monitors provide comfortable viewing with versatile screen height/tilt/pivot/swivel adjustments. You can customize the display condition to create a more personal, comfortable workstation. The monitor can be easily assembled without any tools, and is also able to be wall-mounted (Wall mount sold separately).
MINI PC MOUNTING CAPABILITIES
The BK550 is designed to allow for the discreet mounting of compatible mini PCs on the rear. Using an Intel NUC or 100x100mm wall mount, users can easily mount their mini PC (Bracket and PC sold separately).
Product Description LG 24BK550Y-B - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A
Energy Consumption per Year 31 kWh
Power Consumption (On mode) 22 W
Features USB 2.0 hub
Panel Type AH-IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.274 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Environmental Standards ENERGY STAR Qualified
Compliant Standards CSA, UL, TUV, TUV GS, NEMKO, SEMKO, EMC 2004/108/EC, EN55022:2006, DIN ISO 9241-307, EPA 7.0
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 24BK550Y 24" 1920x1...
£151.20
