FULL HD IPS DISPLAY
Designed for professionals, this Full HD display with IPS technology minimizes color shifts and provides outstanding picture quality from virtually any viewing angle.
INTEGRATED POWER MODULE FOR ORGANIZED WORKSPACES
The power module is integrated with the monitor, helping to reduce the amount of power modules in your workspace.
PERSONALIZED VIEWING ANGLES AND EASY ASSEMBLY
The monitors provide comfortable viewing with versatile screen height/tilt/pivot/swivel adjustments. You can customize the display condition to create a more personal, comfortable workstation. The monitor can be easily assembled without any tools, and is also able to be wall-mounted (Wall mount sold separately).
MINI PC MOUNTING CAPABILITIES
The BK550 is designed to allow for the discreet mounting of compatible mini PCs on the rear. Using an Intel NUC or 100x100mm wall mount, users can easily mount their mini PC (Bracket and PC sold separately).
Product Description | LG 24BK550Y-B - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class A | Energy Consumption per Year | 31 kWh | Power Consumption (On mode) | 22 W | Features | USB 2.0 hub | Panel Type | AH-IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.274 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI-D, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | CSA, UL, TUV, TUV GS, NEMKO, SEMKO, EMC 2004/108/EC, EN55022:2006, DIN ISO 9241-307, EPA 7.0 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 23.8" |
Built-in Devices | USB 2.0 hub |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean |
Features | On-screen Digital Controls, Flicker Safe, Reader Mode, SIX Axis Control, Mercury free, Smart Energy Saving technology |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1.2 Watt |
Connectivity | |
Interfaces | HDMI , DVI-D (HDCP) , VGA , Headphones , 2 x USB 2.0 downstream , USB 2.0 upstream , DisplayPort |
Mechanical | |
Tilt Angle | -5/+35 |
Rotation Angle | 180 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Cable holder |
Cables Included | 1 x DisplayPort cable , 1 x USB cable , 1 x audio cable |
MTBF | 70,000 hour(s) |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
