LG 24GM79G 24" 1920x1080 2ms HDMI DisplayPort LED Monitor
Key features
  • 1ms motion blur reduction
  • AMD FreeSync technology
  • ENERGY STAR qualified
Product codes
A monitor's response time is critical in games. 1ms Motion Blur Reduction allows the precision and accuracy needed to play at a high level. With a response time that is virtually 1ms, blurring and ghosting are dramatically reduced to make the in-game action smoother.
FreeSync reduces the tearing and stuttering that occur between a graphic card's frame rate and a monitor's refresh rate. With FreeSync, gamers can experience seamless, fluid movement throughout games without the need to upgrade your graphic card.
Product Description LG 24GM79G-B - LCD monitor - Full HD (1080p) - 24"
Device Type LCD monitor - 24"
Energy Class Class A
Energy Consumption per Year 35 kWh
Power Consumption (On mode) 24 W
Adaptive-Sync Technology AMD FreeSync
Features USB 3.0 hub
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 144 Hz
Pixel Pitch 0.27675 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors 2xHDMI, DisplayPort
Display Position Adjustments Height, pivot (rotation)
Screen Coating Anti-reflective, 3H Hard Coating
Dimensions (WxDxH) - with stand 56.76 cm x 24 cm x 38.87 cm
Weight 5.94 kg
Compliant Standards FCC Class B certified, UL, cUL, DDC/CI, ERP
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 24GM79G 24" 1920x10...
