LG 24MK430H-B 24" 1920x1080 5ms VGA HDMI LED Monitor
£117.33
Delivery:
Notify me
Key features
  • Full HD IPS display
  • AMD FreeSync
  • Dynamic Action Sync
  • Black Stabilizer
  • Wall mountable
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: HDMI, VGA (HD-15)
Product codes
High Definition with Accurate Colour
1080p Full HD resolution with IPS delivers brilliant images that pop with vibrant detail from any viewing angle.
Clearer, Smoother Image
AMD FreeSync™ Technology and a dynamic refresh rate of 75Hz virtually eliminates screen tearing and stuttering to bring you seamless, fluid movement during high-res, fast-paced games.
React Faster to The Action
Dynamic Action Sync mode allows you to instantly react to your opponents and attack them without any display lag. It synchronizes your senses with real-time scenes in fast-paced games by minimizing input lag.
Enemies Have Nowhere to Hide
Black Stabilizer gives you full visual clarity, even in games where you spend a lot of time in the dark. It synchronizes and brightens the darkest areas, so that you can find enemies hiding in the shadows and shoot first.
Easier User Interface
OnScreen Control is simple and intuitive. You can customise your display options with a few simple clicks.
Convenient and Flexible
Mount the monitor to suit your work or entertainment set up.
Product Description LG 24MK430H-B - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class F
Energy Consumption per Year 35 kWh
Power Consumption (On mode) 24 W
Adaptive-Sync Technology AMD FreeSync
Panel Type AH-IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch 0.2744 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA
Display Position Adjustments Tilt
Screen Coating Anti-glare, 3H Hard Coating
Voltage AC 120/230 V (50/60 Hz)
Colour Matte black
Dimensions (WxDxH) - with stand 55.5 cm x 18.19 cm x 42.1 cm
Weight 3.1 kg
Compliant Standards FCC Class B certified, TUV, SEMKO
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£117.33
Notify me
