LG 24MK600M-B 24" 1920x1080 5ms VGA HDMI IPS LED Monitor
£109.40
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Full HD IPS display
  • Color calibrated
  • 3-side borderless screen
  • Radeon FreeSync
  • OnScreen control
  • Wall mountable
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £112.89
Save £1.50
This streamlined display features a slim bezel on three sides for an immersive visual experience and no distraction from the dazzlingly precise, lifelike image. IPS technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can view the screen at virtually any angle.
Product Description LG 24MK600M-B - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A+
Energy Consumption per Year 25 kWh
Power Consumption (On mode) 17 W
Adaptive-Sync Technology AMD FreeSync
Panel Type AH-IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch 0.2744 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors 2xHDMI, VGA
Display Position Adjustments Tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Matte black
Dimensions (WxDxH) - with stand 48.87 cm x 18.2 cm x 38.67 cm
Weight 2.7 kg
Compliant Standards FCC Class B certified, TUV, SEMKO, DDC/CI, IEC 62087 Edition 2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 24MK600M-B 24" 1920...
£109.40
