LG 27MD5KA 27" 5120x2880 14ms HDMI DisplayPort USB-C Thu...
LG 27MD5KA 27" 5120x2880 14ms HDMI DisplayPort USB-C Thunderbolt Ultra HD IPS LED Monitor
£1,141.78
18 in stock
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 27in
  • Max Resolution: 5120 x 2880
  • Response Time: 14ms
  • Speakers: Speaker(s)
  • Interfaces: Thunderbolt 3
Product codes
Ultra Clear 218 PPI 5K Display
At 218 pixels per inch to deliver 5K resolution (5120 x 2880 at 27") the LG UltraFine™ 5K display lets you experience the definition and detail of a Mac on a large 5K screen.
Rich Color, Better Detail
A color spectrum of P3 99% enables you to edit your high-resolution photos precisely. You will experience exceptional detail and rich color on this 5K display.
5K Display with Thunderbolt™ 3
The LG UltraFine™ 5K display with Thunderbolt™ 3 port can transmit 5K video and data while simultaneously charging a new MacBook Pro (up to 85W) over a single cable. Plus, three USB-C downstream ports (USB 5 Gbps) let you connect additional devices as needed.
Ultimate Visibility
The LG UltraFine™ 5K display reaches a brightness of 500cd/m² and can express a wide range of color and contrast. You can experience vivid, lifelike images on a 5K screen, which provides a more natural representation.
Consistent Color and Clarity
This 5K high-definition monitor with IPS minimizes color shift and delivers detailed, accurate images on the UltraFine™ 5K screen. Color is consistent from edge to edge.
Clear Communication and Entertainment
The LG UltraFine™ 5K display has an internal webcam and responsive speakers/microphone that are perfectly suited to entertainment and communication, allowing you to watch movies, and video chat.
Easy Display Control with macOS
Detailed control of display settings such as brightness can be done using macOS without the need to use any physical buttons.
Multi-Function Screen Manager
The LG Screen Manager has been optimized for macOS to provide a variety of multi-screen options. For example, it can automatically divide the screen into two to four frames, according to users’ specific needs.
Convenient Adjustable Display Stand
LG UltraFine™ 5K displays have convenient height/tilt adjustment. Users can customize the display height to create a more personal, comfortable workstation, or easily wall-mount the display with the use of a VESA mount bracket.
  • 5K (5120 x 2880) IPS Display
  • 218 Pixel Per Inch
  • P3 99% Color Spectrum
  • Built-In Camera & Speaker
  • Thunderbolt™3
Product Description LG UltraFine 27MD5KA-B - LED monitor - 5K - 27"
Device Type LED-backlit LCD monitor - 27"
Features Microphone, camera, USB-C hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 5K 5120 x 2880 at 60 Hz
Pixel Pitch 0.11685 mm
Brightness 500 cd/m²
Contrast Ratio 1100:1
Response Time 14 ms (grey-to-grey)
Input Connectors Thunderbolt 3
Display Position Adjustments Height, tilt
Screen Coating Anti-reflective, 2H Hard Coating
Colour Non-glossy black
Dimensions (WxDxH) - with stand 62.56 cm x 23.99 cm x 46.44 cm
Weight 8.5 kg
Compliant Standards FCC Class B certified, UL, VCCI, BSMI, cUL, CCC, RoHS, REACH, KC, RCM, EPA 7.0, HDCP 2.2, HDCP 1.4
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 27MD5KA 27" 5120x28...
£1,141.78
