LG 27MK430H 27" 1920x1080 5ms VGA HDMI IPS LED Monitor
£137.44
Delivery:
Key features
  • Full HD IPS display
  • Radeon FreeSync
  • OnScreen control
  • Dynamic Action Sync
  • Black stabilizer
  • Wall mountable
  • Diagonal Size: 27in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: HDMI, VGA (HD-15)
Product codes
IPS technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can view the screen at virtually any angle. With Radeon FreeSync, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. Radeon FreeSync virtually eliminates screen tearing and stuttering. Minimize input lag with Dynamic Action Sync so you can catch every single moment in real-time.
You can avoid snipers hiding in the darkest places and quickly escape situations when the flash explodes. OnScreen Control is simple and intuitive. You can customize your display options with a few simple clicks. This monitor gives you the freedom to take it off the desk and hang it on the wall. Liberate your viewing options and save desktop space with this wall-mountable LG monitor.
Product Description LG 27MK430H-B - LED monitor - Full HD (1080p) - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A
Energy Consumption per Year 37 kWh
Power Consumption (On mode) 25 W
Adaptive-Sync Technology AMD FreeSync
Panel Type AH-IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch 0.3113 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA
Display Position Adjustments Tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Matte black
Dimensions (WxDxH) - with stand 62.56 cm x 20.41 cm x 46.87 cm
Weight 4.6 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, UL, TUV, cUL, EN 61000-3-3, EN55024, DDC/CI, EN 61000-3-2:2006, EN 60950-1:2006, EMC 2004/108/EC, LVD 2006/95/EC, EN55022:2006 Class B
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 27MK430H 27" 1920x1...
£137.44
