LG 27UD88 27" 3840 x 2160 5ms HDMI LED Silver/White
Key features
  • USB Type-C
  • On-screen control
  • Black Stabilizer
  • ArcLine design
Product codes
Display video, transfer data and charge a laptop or mobile device, all at the same time using a single cable with USB-C. On-screen control makes it easy to adjust many monitor settings via an on-screen window, with a few easy clicks of your mouse. Keep visibility even in dark scenes. LG's Black Stabilizer sense dark scenes and helps make it brighter so that you can find the enemies hiding and waiting to attack your player in the dark. The sleek design of LG premium monitors is accentuated by the ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance.
LG 27UD88 - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Input Connectors
2xHDMI, DisplayPort, USB
Display Position Adjustments
Height, pivot (rotation), tilt
Screen Coating
Anti-glare, 3H Hard Coating
Silver, white (back)
61.5 cm x 20.54 cm x 42.51 cm
6 kg
Plug and Play, FCC Class B certified, UL, cUL, CB, DDC/CI, RoHS, REACH, KC, EPA
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 27UD88 27" 3840 x 2...
