LG 27UK600 27" 3840x2160 5ms HDMI DisplayPort IPS LED Mo...
LG 27UK600 27" 3840x2160 5ms HDMI DisplayPort IPS LED Monitor
£445.65
Delivery:
Key features
  • HDR 10
  • HDR Effect
  • sRGB
  • AMD FreeSync
  • Gaming features
  • On-Screen Control
  • Ergonomic Stand
  • Diagonal Size: 27in
  • Max Resolution: 3840 x 2160
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI
Product codes
To fully realize content creators' vision, this monitor is compatible with HDR10 high dynamic range, supporting specific levels of color and brightness that exceed the capabilities of ordinary monitors.
The HDR Effect helps transform non-HDR content into high quality video that looks like HDR through its picture quality algorithm.
sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
Product Description LG 27UK600-W - LED monitor - 4K - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A
Energy Consumption per Year 44 kWh
Power Consumption (On mode) 30 W
Adaptive-Sync Technology AMD FreeSync
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160 at 60 Hz
Pixel Pitch 0.1554 mm
Brightness 450 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (grey-to-grey)
Input Connectors 2xHDMI, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Textured black, silver (stand), white (back)
Dimensions (WxDxH) - with stand 61.31 cm x 20.94 cm x 45.52 cm
Weight 5.2 kg
Compliant Standards Plug and Play, FCC Class B certified, UL, TUV, VCCI, cUL, DDC/CI, RoHS, REACH, KC, ERP, EPA 7.0, DisplayPort 1.2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 27UK600 27" 3840x21...
£445.65
