LG 27UK650-W 27" 3840x2160 5ms HDMI DisplayPort IPS LED...
LG 27UK650-W 27" 3840x2160 5ms HDMI DisplayPort IPS LED Monitor
£487.22
28 in stock
Delivery:
Standard: 1-3 working days
Key features
  • HDR 10
  • HDR Effect
  • HDCP 2.2 compatible
  • AMD FreeSync
  • Advanced gaming features
  • On-Screen Control
  • Ergonomic stand
  • Diagonal Size: 27in
  • Max Resolution: 3840 x 2160
  • Response Time: 5ms
  • Speakers: Headphone
  • Interfaces: DisplayPort, HDMI
Product codes
To more fully realize content creators' vision, this monitor is compatible with industry-standard HDR10 high dynamic range, supporting specific levels of color and brightness that exceed the capabilities of ordinary monitors.
The HDR Effect helps transform non-HDR content into high quality video that looks like HDR through its picture quality algorithm.
Connect with confidence: this LG 4K monitor is compatible with the HDCP 2.2 copy protection, so it will display video from 4K streaming services, game consoles and Ultra HD Blu-ray disc players.
Product Description LG 27UK650-W - LED monitor - 4K - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A
Energy Consumption per Year 44 kWh
Power Consumption (On mode) 30 W
Adaptive-Sync Technology AMD FreeSync
Panel Type AH-IPS
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz)
Pixel Pitch 0.1557 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (grey-to-grey)
Colour Support 1.073 billion colours (8-bit)
Input Connectors 2xHDMI, DisplayPort
Display Position Adjustments Height, pivot (rotation), tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Silver (stand), white (back), silver (front)
Dimensions (WxDxH) - with stand 61.5 cm x 20.95 cm x 45.49 cm
Weight 4.9 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards FCC Class B certified, UL, TUV, C-Tick, cUL, SEMKO, EN 61000-3-3, EN55024, CB, DDC/CI, RoHS, Directive 2004/108/CE, Directive 2006/95/EC, EN 61000-3-2:2006, EN 60950-1:2006, EPA 6.0, EN55022:2006 Class B, DisplayPort 1.2, HDCP 2.2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
LG 27UK650-W 27" 3840x...
£487.22
